1eyedjack's avatar
1eyedjack
Optimal config for R7000 and VMDG490?
Hello I have been using R7000 for a while, and contrary to some other posters have been very happy with it (famous last words). Virginmedia have recently "upgraded" my ISP connection and in the pro...
  • rpoffen's avatar
    rpoffen
    Dec 16, 2015
    Just as the modem has "modem mode" and "router mode", the R7000 also has "router mode" and "Access Point mode". When set as an access point, then it disables the routing functions, so all your are using it as is an ethernet hub/switch (by virtue of the 4 LAN ports) and wireless interface. When you do this, the modem does the routing. The R7000 does no routing, so DHCP, QoS, port forwarding, and other functions are not available.
    Typically the R7000 does a better job of routing than most combined modem/router units, particularly those provided by the ISP, so it is usually preferable to have it do the routing. In order to prevent two routers (which can result in NAT problems) from being in the path, you would put your modem into modem only mode.
