Meforgiel's avatar
Meforgiel
Orange light on nighthawk model ax43
Hello! Just set up my router and the internet light is orange (second light right). Why is that and how can i fix it. Thanks
  • Orange indicates 100 Mbps speed instead of 1 Gbps. What's yoour modem? which router do you actually have?
    • Meforgiel's avatar
      Meforgiel
      Thanks for the quick reply. My modem is from my ISP and there is nothing written on it just a black box.
      I just bought and installed the Nighthawk model AX42
      • microchip8's avatar
        microchip8
        Master
        Your title says AX43 but now you say AX42. Which is it?
        Most likely your modem operates at 100 Mbps or if not, your cable is faulty or not CAT5e or higher
