Madscientist-UK
Jan 01, 2017Tutor
Overall dimensions of Nighthawk X10
 Could someone please let me know the overall dimensions of the new X10 including the antenna?    The quoted numbers in the spec seem far too small from the pictures I've seen.     Thanks
- Jan 01, 2017
Yeah i'm not sure where the data sheet is getting those measurements from.
The unit measures roughly 33cm by 22cm, and is 6.5cm high. The antennas are 18cm long, 2.5cm wide at the top and 3cm wide at the bottom.
Hope this helps
clithes
Jan 01, 2017Prodigy
Hope this helps
- Madscientist-UKJan 01, 2017Tutor
Many thanks.
- Madscientist-UKJan 14, 2017Tutor
Just for the record, the overall dimesions including the antanna are:
Width: 36cm, 14.2"
Depth: 27cm, 10.6"
Height: 21cm, 8.2"
The numbers in the spec are fictional
