DeadL
Apr 26, 2017Aspirant
Packet Loss involving R7800, Synergy and Killer 1535 Wireless Network Adapter
Hello, I've noticed whenever I'm using using 'Synergy' to access my Laptop, there is a large increase in dropped packets happening in my 'ping -t google.com' command. (Synergy allows you to use ...
- Apr 26, 2017
Thank you for the quick reply!
I took a look at my Router settings and it looked like everything was already setup similar to your suggestions. Upon further investigation I found that the Router has QoS enabled for Wireless traffic on by default. (At least it was on for me, for some reason).
The settings are located at:
192.168.1.1 > Advanced > Setup > QoS Setup > WMM
I set those two WMM (Wi-Fi multimedia) settings to disabled.
That appears to have fixed the packet loss.
I assume that is because the Qualcomm driver the Killer 1535 is using was performing its own QoS.
I noticed some large latency spikes after disabling that, so I installed the 'Killer Control Center' program and set the Synergy.exe to max priority.
So far, so good.
DeadL
So far, so good.
Apr 26, 2017Guru - Experienced User
Wonder if you can disable any QoS or WMM on Killers adapter as well. Glad you got it working. Enjoy.
