gaug
Oct 11, 2016Aspirant
Parental controls for individual devices
The network map shows the correct settings I selected in the details window, but for some reason the individual devices I chose to leave unfiltered by selecting "None" as the filtering level are sti...
- Oct 17, 2016
Hi gaug,
I think you can only edit those using the admin account or your main account of the LPC. Other users will not have that option.
JamesGL
Community Team
JamesGL
Oct 13, 2016NETGEAR Employee Retired
Hi gaug,
You need to configure the bypass account for each device in order to have their won filtering level.
JamesGL
Community Team
gaug
Oct 14, 2016Aspirant
Thanks for the response JamesGL. I have the bypass accounts set up on the necessary devices already and they do work, but the Netgear Genie literature leads one to believe he or she still has the ability to choose or assign specific devices in the network map and set their filtering level individually. My understanding is that each devices' filtering level can be configured differently, some with the most restictive filtering, others with some filtering and if desired a few with no filters at all. Am I misunderstanding this feature of the network map, or is the router I have incapable of setting different filtering levels on different devices?
- JamesGLOct 17, 2016NETGEAR Employee Retired
Hi gaug,
JamesGL
Community Team
- JamesGLOct 23, 2016NETGEAR Employee Retired
Hi gaug,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
