oppeku
Jun 13, 2026Follower
Password change on Nighthawk AC2300 Smart WiFi Router (R7000P)
How do I change the password for the Nighthawk AC2300 Smart WiFi Router (R7000P)?
Jun 15, 2026Guru - Experienced User
Might start socking away a little money here and there. That R7000P was a decent router. But that was over a decade ago. While it still works for most situations (and is pretty solid), its also getting a bit older, doesn't get updates anymore, and is several generations behind.
But props for getting all you can from it!
