geoff89123
Apr 17, 2018Aspirant
Password for firmware update
Why doesn't my login (which I assume is my email address) and my password work when I am trying to update the firmware at the www.netgearlogin site? I am using the same combo that allows me access to the netgear.com site.
My laarger isssue is I keep getting kicked off my 5G on all of my devices throghout the house. Will this help resolve this issue? The NIghthawk X 4 is two years old, and my Mortoroll MBB600 modem is about 2 months old.
Sure appreciate any help you can offer.
Thank you,
There is a manual for the R7500v2 somewhere at the end of this link:
>>>> Nighthawk R7500v2 | AC2350 Smart WiFi Router | NETGEAR Support <<<<
Check page 106 for what you are trying to do. If the default password does not work, you may have set your own password some time in the past. If you have forgotten it, the only answer is to factory reset the thing (see below).
That link will also get you the latest firmware. It should have release notes that also tell you how to access your router's browser interface. (It isn't a website out on the internet as most people understand it.)
geoff89123 wrote:
My laarger isssue is I keep getting kicked off my 5G on all of my devices throghout the house. Will this help resolve this issue?It might do. That's what firmware is for. The release notes should explain what is fixed, but Netgear rarely bothers to provide much detail.
It might be worth doing a factory reset after the firmware update. (See page 11 in the manual.) Some people see this as superposition, but it has been known to fix problems, especially on the wifi front.
Good luck. If you still have 5 GHz problems, you might want to start a different discussion.
> www.netgearlogin site? [...]
Probably because you're using the wrong credentials. And assuming
instead of reading the documentation. Visit http://netgear.com/support
, put in your model number, and look for Documentation. Get the User
Manual. Read. Look for "Types of Logins".
If we assume that "the www.netgearlogin site" was actually something
like "routerlogin.net", then that should be your own R7500v2, not some
"netgear.com" site (where you might use your e-mail address as a user
ID).
> [...] I am using the same combo that allows me access to the
> netgear.com site. [...]
That'd be wrong.
> devices throghout the house. Will this help resolve this issue? [...]
I don't know. What, exactly, does "kicked off my 5G" mean to you?
As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.- michaelkenwardGuru - Experienced User
- geoff89123Aspirant
Thank you very much. Really appreciate the help. I was able to resolove the issue.
Thanks,
Geoff
That's good.
Did it mend the 5 GHz?
