romeohorn1's avatar
romeohorn1
Follower
Jul 04, 2021
Password recovery not working on C7000v2
My password doesn’t work on admin as username when I type in password for my password code it doesn’t work to login. I want to know what the solution to fix this. I tried on my computer it doesn’t work at all either somebody please help me out.
1 Reply
  • plemans's avatar
    If your password isn't working and password recovery isn't working (or wasn't setup, it still asks), then you're only option to get back in is to do a factory reset and reinstall.
    Push and hold reset for 7-15 seconds while powered on.
