kmharre
Dec 17, 2017Tutor
Pay service sabotage
I purchase the router in November of 2016. It was blazing fast for the first 5 months. I started having speed and consistency issues. I called NG's support line. They sent me to the pay for servi...
- Dec 26, 2017
William10a,
My apologies for not responding sooner. It was apparent from your first reply that you are desparately seeking a life. When i state that no response was necesary, it was more than a suggestion.
As far as getting a life, i suggest starting with face-to-face communications. You may want to tone-down the belligerence. You may recall the "little green men" statements you made as well as other petty jabs.
Since i have a busy life, i won't respond more to you.
michaelkenward
Dec 18, 2017Guru - Experienced User
kmharre wrote:
Call me paranoid, i suspect the service provider of messing with my router.
If you insist, you are paranoid.
If you think the service provider is messing with your router, why does Netgear get the blame?
Seems to be a jump in logic there.
- kmharreDec 18, 2017Tutor
No jump in logic. I just followed the dots. The timing was quite conspicuous.
I called Netgear support for help. They directed me to Netgear pay for service group. The provider insist they were a unit of Netgear.
- michaelkenwardDec 18, 2017Guru - Experienced User
The jump in logic was that you seem to blame your Internet service provider for spying on you and then Netgear for your router's problems.
Are you saying that you think that Netear told your ISP that your support contract was up and then the ISP mucked up your router? (Hard to know how it could do that as neither Netgear nor your ISP has an access to your router's configuration.)
It is much more likely that this was pure coincidence. Or maybe little green men.
Oh, and if your router had died, there were still at least 98 months more to tun on the warranty.
The more I think about it, the more I buy into the little green men theory.
Whatever you do, avoid paying for support. Most people turn to this forum for help, where the solutions offered may well be better than those delivered by the script jockeys in the offshore call centres.
HaHa!! Please read the text carefully. I stated "service provider," not "internet service provider." The service provider is the Netgear pay for service company.
No need to respond.
