kmharre
Dec 17, 2017Tutor
Pay service sabotage
I purchase the router in November of 2016. It was blazing fast for the first 5 months. I started having speed and consistency issues. I called NG's support line. They sent me to the pay for servi...
- Dec 26, 2017
William10a,
My apologies for not responding sooner. It was apparent from your first reply that you are desparately seeking a life. When i state that no response was necesary, it was more than a suggestion.
As far as getting a life, i suggest starting with face-to-face communications. You may want to tone-down the belligerence. You may recall the "little green men" statements you made as well as other petty jabs.
Since i have a busy life, i won't respond more to you.
William10a
Dec 22, 2017Master
I was wondering Genie would be a danger if anyone just enter your with it when they wanted and by pass your password and login name. Any line of security for the intenet has a way around it but without some key pieces of information they are locked out.
kmharre
Dec 26, 2017Tutor
William10a,
