R7000_uzer
May 31, 2021Aspirant
Phone can’t connect through R7000
Can’t connect to a lawn mover.
R7000_uzer
Jun 01, 2021Aspirant
It did work earlier with another router and the R7000 do find both the phone and the lawn mover.
R7000_uzer
Jun 13, 2021Aspirant
I guess this forum is usless.
- antinodeJun 13, 2021Guru
Something is useless. You might benefit from the results of a Web
search for:"life is like a sewer"
> Can't connect to a lawn mover.
"Can't" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.Is a "lawn mover" anything like a "lawn mower"? Do you think that
any of your readers knows which make and model "lawn mover" you have?> It did work earlier with another router [...]
Not a very detailed description of that device, either.
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0Nothing to do with anything?
- R7000_uzerJun 15, 2021AspirantOk, yes a worx landroid wg796E.1 and the other router was a Comviq something…
- michaelkenwardJun 16, 2021Guru - Experienced User
R7000_uzer wrote:
Ok, yes a worx landroid wg796E.1 ...This?
What do you want to do with it?
R7000_uzer wrote:
...the other router was a Comviq something…What's that?
