R7000_uzer
May 31, 2021Aspirant
Phone can’t connect through R7000
Can’t connect to a lawn mover.
R7000_uzer
Jun 15, 2021Aspirant
Ok, yes a worx landroid wg796E.1 and the other router was a Comviq something…
michaelkenward
Jun 16, 2021Guru - Experienced User
R7000_uzer wrote:
Ok, yes a worx landroid wg796E.1 ...
This?
What do you want to do with it?
R7000_uzer wrote:
...the other router was a Comviq something…
What's that?
- R7000_uzerJun 16, 2021AspirantYes correct,
I want error message when it can’t continue mowing. Never mind, I don’t have the comviq router anymore.- michaelkenwardJun 16, 2021Guru - Experienced User
R7000_uzer wrote:
Never mind, I don’t have the comviq router anymore.Does that mean that your problem is solved?
You aren't making it easy for anyone to understand what is going on at your end and what you want to do.
- R7000_uzerJun 16, 2021AspirantMaybe not, I just don’t want to bother poeple to much
