godeepdown's avatar
godeepdown
port blocked
I am running a CM700 modem and a R6400-v2 router and need to have access to port 8883. If i run a check it says it is blocked. I called Comcast and they say it is not on their end and I need to talk to Netgear. How can I open up the port? I cannot get the device I need it for to connect so I do not have an IP to forward it to. It is a dumb device a smart hub for a garage door that connects to wifi only, so nothing I can configue on it until it connects. The device worked fine until yesterday and then just stopped. The company says it is working fine I just need port 8883 to connect it.
Thanks
Jeremy
  • > [...] I cannot get the device I need it for to connect so I do not
    > have an IP to forward it to. [...]
       "the device"?  If it's not connected to the router, then how do you
    expect the router to forward anything to it?
    > [...] It is a dumb device a smart hub for a garage door [...]
       Thanks for that detailed and precise description.
    > [...] The company [...]
       Better and better.
    > [...] The device worked fine until yesterday and then just stopped.
       Sounds to me as if there might be some kind of problem with
    something.
       Does your (unspecified) "a dumb device" appear in an Attached Devices
    report on the R6400v2?  If not, then have you tried connecting it again?
    Does its (unspecified) maker provide any instructions for it?  LED
    indicators?  Any useful information at all?
    • godeepdown's avatar
      godeepdown
      Ok it is a Chaimbelain My-Q smart hub. I have tried connecting it multiple times over the past day. I have been on the phone with their support, who told me it needs access to port 8883 and told me to contact Comcast. I was on the phone with Comcast and they said they do not block that port and to call Netgear. I do not see the device in the log. I connected a pc directly to the modem and it still says port 8883 is blocked. Has led light and the blinking blue light means it failed to connect and that's what I get. Is the hub broken, maybe but I can not prove that until I get access to port 8883.
      • antinode's avatar
        antinode
        Guru
        > [...] Chaimbelain My-Q smart hub. [...]
           Close enough.
        > [...] I have tried connecting it multiple times over the past day.
           "tried" is not a very detailed description of anything.
        > [...] their support, who told me it needs access to port 8883 [...]
           Forget port 8883.  No port matters to anyone until you get the myQ
        smart hub connected to your router.  Also, if the myQ smart hub creates
        its own outgoing connection using port 8883, which would be my guess,
        then neither your ISP or your router is likely to stop it.  Port
        forwarding is used for _incoming_ connections; it's not needed for
        _outgoing_ connections.
        > you expect the router to forward anything to it?
           Still a mystery.
        > [...] I do not see the device in the log. [...]
           Which "the log"?
        > report on the R6400v2? [...]
           Still a mystery.  This whole operation might make better progress if
        you answered the questions (as asked).
        > [...] I connected a pc directly to the modem and it still says port
        > 8883 is blocked. [...]
           If your whole network consists of your CM700 modem and some Windows
        computer, then there's no point in looking for any information about any
        ports.  Forget port 8883.
        > and that's what I get. [...]
        > [...] If not, then have you tried connecting it again?
           Still a mystery.
        > [...] Is the hub broken, maybe [...]
           If it was working, but now is not, then my guess is that something
        went wrong which caused it to stop working, but I can't see how you've
        tried to reconfigure the thing, so I wouldn't bet either way.
           Can other wireless devices connect to your router (presumably using
        the 2.4GHz radio band)?
        > [...] but I can not prove that until I get access to port 8883.
           Nonsense.  Forget port 8883.  Is there anything in the basic myQ
        smart hub instructions which tells you to worry about port 8883?
        Perhaps there's a reason for that.
           Any port like 8883 would be involved in communication between your
        myQ smart hub and some computer in the outside world which Chamberlain
        runs so that your mobile phone can easily talk to your myQ smart hub.
        It has nothing to do with the wireless-network set-up between your myQ
        smart hub and your router.
           My quick Web search found:
              https://support.chamberlaingroup.com/s/article/How-to-Connect-the-Smart-Garage-Hub-to-a-Network
           Did you follow those directions?  Step by step, what did you do, and
        what happened when you did it?
           Concentrate on getting a wireless-network connection established
        between your myQ smart hub and your router.  Forget port 8883.
