Skip_007
Jun 24, 2016Aspirant
Port Forwarding - 2 PCs
My wife and both play LOTRO and it seems that there is a requirement for port forwarding. The question that I have revolves around the fact that there are 2 computers involved. Is it possible to forward the same ports to 2 pcs? If not what about port triggering to do what I need to do. I need to forward ports 9000 - 9100. If in fact port triggering is the way to go I think I understand how to do the first one using port 9000 as the triggering port, but what about the second computer? Do I use the exact same thing or something different? We do both play at the same time most of the time? Thanks in advance for any help or insight that you can provide. Hope you have a SUPER Day!!!
Hi kokeysian,
I believe that your router was supplied by your ISP based on the firmware version (CH suffix) that you have provided. Please check with your ISP if there are any updates or if this is something the can fix since the retail versions do not have this issue.
Dexter
Community Team
LOTRO has a post on their website that specifically addresses this (here). They recommend port triggering. With port triggering you don't specify an IP address, so just create a single rule for ports 9000 - 9100. LOTRO also recommends a modification to a userpreferences file on one of the computers to use port 9000. Starting the game on this computer will trigger the ports to be opened. The second computer should then be able to use the opened ports.
- Skip_007Aspirant
I saw that and thought about it. I guess my question should have also included the fact that if I do that it should work great if I log on and I assume even off and my wife logs on after I do and stays on. My concern is if she logs on and I don't what happens. I guess my question is, assuming that I cannot forward the same ports to 2 computers. What do I do about the second computer, using the example LOTRO provided would or could I use port 9000 or say 9001 on her computer to trigger the forwarding. If so what happens if I sign on and then she does or the other way around. I am probably not explaining this as well as I should, but hopefully you can make some sense of it. Thanks.
I'm guessing that if your wife is playing by herself, then it will also try port 9000 and it will succeed.
