Myiah's avatar
Myiah
Ports Closing on Netgear Nighthawk X8
Hi.
I have an Nighthawk X8.  I have port forwarding setup on the router along with static ip address saved for different devices on the network. We also use filemaker remotely. Every so often I have to reboot the router  in order for the port to open back up. It is like it has to refresh. Once it reboots we are able to connect remotely again.
What could be the problem with this? any suggestions will help.
Thanks in advance
    • Myiah's avatar
      Myiah
      We are connected to filemaker remotely on port 5003
      We can connect just fine. Its just every so often we have to reboot the rooter because the port closes and we cannot connect.
      But once we reboot the router we can connect again.
      Hope that makes sense
