RalphRoss's avatar
Nov 04, 2016
Power Outage NightHawk 6.0, Now Can't Login to Router
I saw almost the exact problem in forums from 2012 for older Netgear routers - but didn't see a good answer. It won't let me enter the correct model number but this is a new Nighthawk R8000 AC3200wit...
  • JamesGL's avatar
    Nov 07, 2016
    Hi RalphRoss,
    Disconnect the R8000 first from the Arris modem. Access it and make sure that it was not set to AP mode. If still can't access, reset the router to factory default.
    JamesGL
    Community Team
