TheComputerHyp
Dec 01, 2021Guide
Priority alwaystatus?
When viewing my "Attached devices", their Priority always shows as "low". If I edit the device and change its priority, then return to "Attached devices", its priority will still show "Low". But if I go back into edit, it shows the new changed priority. Why? What is the device's true priority?
Where are you looking. There are various places where you can view Attached devices.
And your hardware is?
"Priority" ALWAYS shows as "Low" in Advanced tab/Administration/Attached Devices.
However, when I go to edit a device on which I have previously set the priority to "Normal", the status shows as "Normal" in "Edit Device" but shows as "Low" when I return to Advanced tab/Administration/Attached Devices.
Router: RAX75
OS: Win 11 Pro
