Pupchops
Jun 30, 2018Aspirant
Problem configuring Nighthawk AC1900 D7000 with OpenVPN
First of all, I have followed these instructions: https://kb.netgear.com/29826/How-do-I-use-VPN-on-my-Nighthawk-router-with-my-iOS-device Also, I know that I have successfully configured DDNS via a...
- Jun 30, 2018
The Remote Access port must be different from the port(s) configured for OpenVPN - to _not_ configure the remote port to match the OpenVPN ports! And no port forwarding for the OpenVPN Server ports - the VPN server does run direct on the router.
In general, the correct port (as configured, UDP or TCP) is included in the configurations readily available from the router for download and installation.
Last but not least, to test the OpenVPN environment use a different Internet connection, just the 4G network, ...
schumaku
Jun 30, 2018Guru - Experienced User
