n1mm
Sep 27, 2016Aspirant
Problem using HTTPS with ReadyShare
Setting up Readyshare to allow access to a thumb drive from the internet. Works fine, except that the connection is HTTP and not HTTPS. I could deal with no support for HTTPS, but there is no way to specify the link as HTTP and have it work. The port must be 443 or >= 1024. In any event, if you try to access with HTTP:// it fails, if you use HTTPS:// you get this:
There’s a problem with this website’s security certificate
This might mean that someone’s trying to fool you or steal any info you send to the server. You should close this site immediately.
Go to my homepage instead
Continue to this webpage (not recommended)
If you continue to the web page, you get access to the data. I haven't found anyone else reporting this problem, so I have not found a workaround. Any ideas?
I got this reply from level 3 (via level 2) support:
Engineers confirmed that this is a device limitation and there is no security issue even if you are getting this message.
Please see engineers comment:
"This is a known limitation of all our product, NETGEAR only put this self-signed certificate in FW but not public to root server. Browser will give a warning but user can access page continually without issue. "
"This will not impact security, this just a warning regarding the certification is not recognize but public."I will ask for the ability to use port 80 to avoid the error messages.
- JamesGLNETGEAR Employee Retired
Hi n1mm,
Please check the KB article below on how to access ReadyShare.
JamesGL
Community Team
- n1mmAspirant
Unfortunately, that doc does not correspond to what I see for that page on my router. I am running V1.0.2.04. In that version, the link name for the internet http link starts with HTTPS, not HTTP. Further, the port is restricted to 443 or >= 1024. The doc is not useful for my problem.
I guess no one is running V1.0.2.04 and trying to use this.
Hi n1mm,
Can you post the screenshot of the ReadyShare page of your router.
JamesGL
Community Team
