drfred
Jul 09, 2018Tutor
Problems with AP mode
I am having major problems trying to set up my router in AP mode. Using an R8000 in conjunction with a Juniper SRX240 router
I was previously using the R8000 for home use, but my network traffic got too high and I had to keep resetting the router. Have now gone to an enterprise router for basic needs, but would like to set up the R8000 as an Access Point.
First of all, resetting the R8000 to factory defaults is no easy trick. Using the instructions to hold the reset button until the power button blinks amber took at least 4 attempts to get the thing back to factory settings. Anyway, now it is back to factory, as I can see from the SSID being NETGEAR18.
The documentation is really lousy as it usually refers to "connect to the rotuer" but there are multiple ways to do so. Documentation should be very specific as far as saying "use an Ethernet cable to connect to one of the four ports" or "connect to the Internet port".... anyway, enough of my rant. Sorry.
Now when I boot up the device, and connect using a standard network cable to one of the four regular ports on the router, then use a browser (IE in this case, although I have also used Chrome) to access http://routerlogin.com it brings me to a page in which it asks me to select whether or not to update the firmware automatically, and whether to send router analytics to Netgear. After that, I get a page where it says it is detecting whether another router exists on the network.
At this point I am only connected with a laptiop to the router - no other connections to the R8000. I have not had any success with having the R8000 hooked up to the SRX240.
Next it asks whether I want the genie to help, but I say no - I will do it myself. Then I get a page where I set up the admin password and security questions.
So far so good. Now I log into the router and get the standard router access page.
Now starts the problem. The documentation states that going to ADVANCED > Advanced Setup > Wireless Settings I should have the option of getting an IP dynamically or setting one myself - this makes sense. Unfortunately in my firmware, V 1.0.4.18_10.1.49 I don't have that option. the only option I have is ADVANCED > Advanced Setup > Wireless AP then to turn on AP mode. When I check that box, it says that it will take about 2 minutes for the router to reboot, but at that point I lose all access to the router.
The router then reboots, and broadcasts an SSID NETGEAR18 which I can connect to, but I cannot ever see any setup page after that. I cannot connect to the router by cable plugged into one of the regular ports or the internet port using a browser and going to routerlogin.com, routerlogin.net, 192.168.1.1, or 10.0.0.1. I have no idea where the router is. Assuming that it is working in AP mode, I try to connect it to the SRX240 using an ethernet cable from the internet port as the documentation says, but it does not work.
I have also tried to set up the router in router mode to a fixed IP at 192.168.1.252, then switching it to AP mode, but the router is no longer accessible at 192.168.1.252. When operating in AP mode, should it not still have some sort of status or setup ability? All my other APs work that way...
I would think that I should still be able to access some setup page where I could change the IP or the SSID, but I have had no luck so far.
Any ideas?
> The documentation is really lousy [...]
Complaints about "The documentation" might benefit from some
description of which "The documentation" is being discussed, too.
> [...] Documentation should be very specific [...]
Agreed. Just like complaints about "The documentation".
> [...] I am only connected with a laptiop to the router - no other
> connections to the R8000. [...]
Ok. That's a reasonable way to configure an R8000 as a wireless
access point. (Up to a point.)
> [...] I should have the option of getting an IP dynamically or setting
I haven't touched an R8000, so I know nothing, but, on other models
(like, for example, my D7000 (V1.0.1.64_1.0.1), and an R7000
(V1.0.7.12)), checking the box at "Enable Access Point Mode" reveals the
"Choose IP Address settings on this access point" choices, as described.
Scrolling down doesn't help on yours?
> [...] When I check that box, it says that it will take about 2 minutes
> router.
Around here, the default choice is "Get dynamically from existing
router", and that works only if the router-as-WAP can talk to a DHCP
server on your network, which it can't do if it's not connected to your
network.
> [...] I cannot connect to the router by cable plugged into one of the
> routerlogin.com, routerlogin.net, [...]
Those names work only if the R8000 is acting as a router (and DNS
server), and should fail if the R8000 is acting as a WAP.
> [...] 192.168.1.1, or 10.0.0.1. [...]
Similarly, if the R8000-as-WAP is getting its LAN IP address
"dynamically from existing router", it would need to be connected to
"existing router", and neither of those addresses is very likely to be
the address it would get if it were. (And, if it's not, then it will
have no LAN IP address, only frustration.)
> [...] I have no idea where the router is.
It won't "Get [its LAN IP address] dynamically from existing router",
until it's connected to "existing router" (DHCP server).
> [...] Assuming that it is working in AP mode, I try to connect it to
What, exactly, "does not work". If you're trying to get your web
browser to talk to the R8000-as-WAP, then you'd need to know its
address, and, so far, only the main router (DHCP server) knows what that
is. If the main router offers some kind of Attached Devices or DHCP
Clients report, then that should show the R8000-as-WAP, and the address
shown there should lead to the R8000 managment web site.
> [...] I have also tried to set up the router in router mode to a fixed
> IP at 192.168.1.252, then switching it to AP mode, [...]
"in router mode", the R8000 has two IP addresses, WAN/Internet and
LAN. As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Given the existence (supposed for you, actual for me) of that "Choose
IP Address settings on this access point" choice, I'd guess that a
manually set router-mode LAN IP address would not survive the change to
WAP mode. I'd guess that you'd get either the default ("Get dynamically
from existing router"), or else whatever you specified for "Use fixed IP
Address (not recommended)" when it provided places for user-specified
values for:
IP Address
IP Subnet Mask
Gateway IP Address
Primary DNS
Secondary DNS
So, if your R8000 really doesn't ask you to "Choose IP Address
settings on this access point", then I'd assume that it's defaulted to
"Get dynamically from existing router", and I'd ask the "existing
router" (DHCP server) where the R8000-as-WAP might be.
> far.
You should, but finding the R8000-as-WAP may be a little less
straightforward than you might expect. But, aside from the missing
"Choose" choice, it should all make sense if you look at things from the
point of view of the R8000.
> router.
network.
values for:
IP Address
IP Subnet Mask
Gateway IP Address
Primary DNS
Secondary DNS
> far.
point of view of the R8000.- drfredTutor
First of all. thank you for being willing to help me. I DO appreciate the help. Not trying to be an a**hole but sometimes I get that way.
I will try to answer your questions from this post.
>description of which "The documentation" is being discussed, too.I was referring to the Netgear documentation provided with the router, and the FAQs online. I fully understand that the documentation is geared toward the "average" user out there who is not trying to do the types of things that I am trying to do, but in general I find Netgear's documentation to be extremely vague and unhelpful.
>network.Yes, I now see that option and have tried it.
>shown there should lead to the R8000 managment web site.When i put the the R8000 into AP mode, it is assigned an appropriate IP address by the SRX240 router. After that, attempts to access that IP address gets me nowhere. The address is 192.168.1.10. I have connected to the device with a laptop and an ethernet cable both to the WAN port, and also to one of the other 4 ports on the device. There is no response from the device at 192.168.1.10. I have tried connecting to the device using a browser, and I have tried to ping the device. Once it has been assigned an IP in AP mode, I do not seem to be able to make any connection to the device.
The device does broadcast 3 SSIDs: NETGEAR18, NETGEAR18-5G-1, and NETGEAR18-5G-2. I can "connect", meaning the handshake and password check establish a connection, and the device is sitting out there at 192.168.1.37. Attempts to ping that address or connect to that address using a browser time out.
>descriptions or interpretations.Hopefully the above has cleared up this point...
>values for:
> IP Address
> IP Subnet Mask
> Gateway IP Address
> Primary DNS
> Secondary DNSI have tried this option as well. I put in 192.168.1.252 as the IP, 255.255.255.0 as teh subnet mask, 192.168.1.1 as the gateway, 208.67.222.222 as primary dns, and 8.8.8.8 as secondary DNS. When I hit "apply" the device did not go to 192.168.1.252, but requested an IP from the existing router. It is now sitting at 192.168.1.10. Strange behaviour, would you not agree? This is why I believe that Netgear says that this option is (not recommended) because they know it does not work.
0 Kudos > When i put the the R8000 into AP mode, it is assigned an appropriate
> address gets me nowhere. The address is 192.168.1.10. [...]
That's plausible. How did you determine that address?
> [...] I have connected to the device with a laptop and an ethernet
> device.
You lost me. If the R8000-as-WAP is connected to the SRX240 (so that
it gets a LAN IP address from the SRX240 DHCP server), then how does
your "a laptop" get anywhere near its WAN port? What, exactly, is
connected to what, exactly? Each cable has two ends, and each router
has multiple ports, so a useful description would specify exactly which
port gets each end of each cable.
> [...] There is no response from the device at 192.168.1.10. I have
> the device. [...]
If the R8000 firmware is ok, and if the R8000-as-WAP LAN IP address
really is "192.168.1.10", then another computer on the "192.168.1.*"
subnet should get a response to "ping" and to a web browser directed at
that address. As I said, this stuff worked for me with my R7000. One
explanation of your failure would be that "192.168.1.10" is not the LAN
IP address of your R8000-as-WAP.
> [...] I can "connect", meaning the handshake and password check
Again, I'm lost. What, exactly, is at "192.168.1.10"? What,
exactly, is at "192.168.1.37"? Determined how, exactly? I don't see
how the R8000-as-WAP can be at both "192.168.1.10" and "192.168.1.37".
Not even slightly.
> [...] It is now sitting at 192.168.1.10. Strange behaviour, would you
> not agree? [...]
What is "sitting at 192.168.1.10"? It would be strange, if it were
true, but, between "192.168.1.10" and "192.168.1.37", I really have no
firm idea what the LAN IP address of the R8000-as-WAP actually is (or
how you determined it).
> [...] This is why I believe that Netgear says that this option is (not
It works as expected on my R7000. Before, I tried it with "Get
dynamically from existing router", and it got a pool address
("10.0.0.225"). Just now, I reset my R7000, connected a MacBook (with
Safari) to it, and configured it as a WAP with a static address
("10.0.0.222", outside the pool), and, after the usual reboot, and
connecting its WAN port to (an Ethernet switch on) my LAN, I could talk
to its web site from the MacBook connected to one of the R7000 LAN
ports, or from another system on the main LAN segment (on the WAN side
of the R7000) at that address ("10.0.0.222"). As expected. On the
R7000, ADVANCED > ADVANCED Home: LAN Port says:
MAC Address C4:04:15:1A:19:F7
DHCP On (A mystery.)
IP Address 10.0.0.222
IP Subnet Mask 255.255.255.0
Gateway IP Address 10.0.0.1 (My D7000 -- main router.)
Domain Name Server 10.0.0.140 (My own DNS server.)
10.0.0.1
On the D7000 (main router), BASIC > Attached Devices : Wired Devices
includes:
Allowed R7000 10.0.0.222 C4:04:15:1A:19:F7 Wired
(And, before, it was at "10.0.0.225", a pool address.)
So, at least on an R7000 (V1.0.7.12_1.2.5), I see no problems with
the R7000-as-WAP getting an unexpected IP address whether configured
with "Get dynamically from existing router" or with "Use fixed IP
Address (not recommended)".
As before, you're throwing IP addresses around ("192.168.1.10",
"192.168.1.37") without providing any clues as to how/where you got
them, so I have no idea if either of them belongs to your R8000-as-WAP.
Still true.
When you did this:
> as secondary DNS. When I hit "apply" [...]
did you actually point a browser at (or "ping") "192.168.1.252"?
> [...] When I hit "apply" the device did not go to 192.168.1.252, but
> requested an IP from the existing router. [...]
How did you determine this? As before, an accurate, detailed
description of actual actions and actual observations can be much more
interesting than what you think they all mean.- drfredTutor
From the SRX240 router management page
>port gets each end of each cable.Yes, the R8000 is connected to the SRX240 via an ethernet cable plugged into the WAN port. It should have no other physical connections in AP mode. The only time I connected the laptop to the R8000 WAN port was after trying to connect to the R8000 other ways and failed, I disconnected the R8000 from the SRX240 and connected it to the laptop. via the WAN port, but attempts to access the device: using a browser with
routerlogin.com
routerlogin.net
192.168.1.10
yielded no response.
>IP address of your R8000-as-WAP.I have the MAC address of the R8000. The SRX240 reports connection from that MAC address to 192.168.1.10 via DHCP.
>how the R8000-as-WAP can be at both "192.168.1.10" and "192.168.1.37".I am sorry that I have not been able to explain this better. I have about eight computers around me, so things can get confusing. The SRX240 reports that a device with the MAC address of the R8000 has connected via DHCP to 192.168.1.10.
I connected to the router using an iMac through WiFi SSID NETGEAR18 (or NETGEAR-5G-1, or NETGEAR18-5G-2) The iMac reports that the device it has connected to is at 192.168.1.37.
I get it that your R7000 works in AP mode. I believe you. I really do. You don't have to convince me. I am saying that my R8000 does NOT work in AP mode, and the behavior of the device is very odd. I think it is probably quite buggy. I am trying to figure out if there is a workaround.
- drfredTutor
My error (although I blame poor interface design) I did not see the options that became available after checking the box. Now that I scrolled down I get the options to get an IP address from DHCP or configure a static address (not recommended).
So why exactly is a static address not recommended? This could mean a lot of things. Some people feel that static addresses make a mess of the network, and better to let the devices sort it out themselves. Other people think that in a structured network, static addressess are ok. I just went through a mess to get NAT type 2 for the PS4 on an enterprise router, so I say that static IP addresses are OK.
On the other hand, sometimes manufacturers will say that a feature is "not recommended" because the software is buggy and they know that people will run into problems. All software does exactly what we tell it to do, but what is clear to the coder is not always clear to the user.
Anyway, anyway (we can have a philosophical discussion any time, but it tends to take away from getting the actual work done...:)
So I choose to set an IP myself. 192.168.1.252 subnet mask 255.255.255.0 gateway 192.168.1.1, and DNS servers - switch to AP mode and what happens?
The device reboots, does not use the assigned address, but instead gets one from DHCP and lands at 192.168.1.10. Fine. But I cannot connect to it.
The device is sitting out there dead. It wont ping. Helpfully it does transmit SSIDs, NETGEAR18, NETGEAR18-5G-1, and NETGEAR18-5G-2, and the IP address displayed there is 192.168.1.37
This happens no matter how I try to make this thing work. As soon as I try to get it to go to AP mode, it goes spacey....
> So why exactly is a static address not recommended? [...]
Presumably because the default settings in Netgear routers put
(nearly) the whole subnet into the DHCP pool, so if the user simply sets
a static (not reserved) address on some device, and does not shrink the
DHCP pool accordingly, then the DHCP server could still issue that
address to some other device, causing a conflict.
There's nothing wrong with static addresses, if managed properly.
Expecting typical consumers to manage them properly might be
unreasonable.
> one from DHCP and lands at 192.168.1.10. [...]
Determined how?
> [...] Fine. But I cannot connect to it.
"cannot connect to it" _how_? Depending on what that means, it
begins to sound like bad firmware. Or you're using the wrong address.
Define "dead". It doesn't _respond_ to a "ping" (from where)? As
usual, showing actual actions with their actual results (error messages,
LED indicators, ...) can be more helpful than vague descriptions or
interpretations.
> NETGEAR18-5G-2, [...]
So, not what I'd call "dead".
> [...] and the IP address displayed there is 192.168.1.37
Whose "the IP address displayed" _where_ is "192.168.1.37"?
