litch12's avatar
litch12
Follower
Apr 18, 2022
Problems with router or internet?
I started having random connection problems. My internet has gone down maybe 4-5 times this week alone. This is very rare normally. I have Spectrum and have never had issues, mostly. I pay for 100mbps internet because I’m a gamer, PS5, Xbox, PC, switch. I have two smart TVs, Alexa’s, my iPhone and a tablet and my girlfriend will bring her stuff over occasionally too. I figure this is well enough as most of the stuff isn’t being used at once. I’m starting to think it’s my Netgear Nighthawk R6700v3. How do I tell if it’s faulty? It’s only a little over a year old but every time I try to check for firmware updates on the app it just says “there was a problem checking for firmware”. Does this affect my internet if I don’t update firmware? It was suppose to be easy. I just have no idea if it’s a spectrum thing or my router.
1 Reply
  • plemans's avatar
    1. what modem/gateway is it connected to?
    2. what firmware version are you on? You can compare your version to the one on the support site.
    3. what actually happens when you're having issues? (details are key). For example, do wired devices drop? Do wireless devices say "connected, no internet"? Does the wireless ssid stop broadcasting? Do the lights on it show its rebooting? What is actually going on with it?
    4. What fixes the issue when it happens?
    https://www.netgear.com/support/product/r6700v3
