Nali
Mar 05, 2021Aspirant
ProSupport help
Hello, I need help contacting ProSupport. My router is incapable of putting out a steady stream of Wi-Fi, I've already called my ISP to repair everything on their end, and I've gotten a full equipment swap so it's not their fault. The light on the router where it displays whether it has internet connection blinks every few seconds, sometimes multiple times a second, and other times will go out completely for a few seconds. However, when I am wired into it, I don't lose signal. So when I am connected to Wi-Fi, I can't stream TV, or even stay connected to a video game for longer than 10 minutes at a time without dropping. I paid a lot for this router, and I paid for ProSupport, and after the mess I just went through trying to find a way to contact them and coming up empty, it's hard for me to say I'm getting my money's worth in either regard. Thank you for your help.
Firmware is v1.0.5.28.
- DarrenMSr. NETGEAR Moderator
You will need to use this link to contact support.
https://www.netgear.com/support/contact.aspx
DarrenM
- NaliAspirant
The only contact information I'm given is to buy GearHead, which I'm not, because that was the entire purpose of buying ProSupport so that I'd have a "Support" service I could call. And it's advertised that way as well. You get the extended warranty as well as access to some supposed support service that doesn't seem to actually exist.
- NaliAspirant
Hello? I still need help
