duckware
Jan 21, 2018Prodigy
QoS is gone -- no way to give cloud security cam highest upload priority
Upload QoS is gone, after being in Netgear routers for a VERY long time. That feature has been removed. Netgear support could care less. Their response is 'so, that is just the way it now is'.
I need to give a device (by MAC address, or otherwise) highest upload priority, but can not with Netgear routers. Anyone have any suggestions for alternatives?
Hi duckware,
If QoS is enabled, go to attached devices. Select on the device and select priority.
No RepliesBe the first to reply
