goldenflash81
Apr 07, 2017Aspirant
Quick VPN question - hard drive size
I'm a newbie when it comes to setting up a VPN. The step by step instructions on setting up a VPN on the r6700 mention a USB hard drive attached to the router. How big does the drive have to be? Is 1...
- Apr 07, 2017
Not sure where you might have seen this requirement. Nothing the like ie. here How do I use the VPN service on my Nighthawk router with my Windows client?
schumaku
Apr 07, 2017Guru - Experienced User
- goldenflash81Apr 07, 2017Aspirant
I must have been reading another description, because I don't see any mention of it on the link you posted. Thanks!
