larryB1607
Aug 22, 2026Aspirant
R6020 factory reset Borks internet access
I was getting really slow connection speeds so I did a factory reset. Now I cannot get into the settings so I can update the firmware. I have the latest version on a flash drive. I can see that th...
Aug 22, 2026Guru - Experienced User
larryB1607 wrote:The usual browser router access urls like 187.162
Nothing usual about those URLs. 187.162.x.x are public IP addresses belonging to a Mexican ISP - they are not addresses you can use to access the router from the LAN. Did you try http://www.routerlogin.net ?
- larryB1607Aug 24, 2026Aspirant
Thanks for the reply, I do not own a smart phone and my chromebook cannot run the night hawk app. I clear the browser cache regularly.
- StephenBAug 25, 2026Guru - Experienced User
No need for the nighthawk app. Try entering http://www.routerlogin.net in your chromebook browser.
- larryB1607Aug 30, 2026Aspirant
I have been to that site several times before seeing this. I am unable to find where I am supposed to be able to get into my routers settings so I can install the latest firmware.
