Gru_11's avatar
Gru_11
R6080 Internet disconnects for complete night
From the past one week, The internet link in the router disappears post 12 midnight. Internet gets cut off. Contacted ISP, they have confirmed that there is not issue from there end as rest of the community has a stable internet. How to fix this? Morning again the internet will be back
  • plemans's avatar
    What modem/gateway is it connected to?
    What firmware is on it?
    is it at exact times? LIke there's been a schedule setup?
    • Gru_11's avatar
      Gru_11
      It’s directly connected to the LAN, no modem is connected. From the past few I am facing the issue. Post 12 am the net get disconnects automatically probably till 8am.
      • plemans's avatar
        And that lan is connected to something. If that's whats disconnecting, so with the router
    • Gru_11's avatar
      Gru_11
      No modem or gateway
      Firmware V1.0.0.22
      Yes. Exactly at 12 the internet is getting shutdown
      Schedule setup is unticked
