Sasquatch3000's avatar
Jul 15, 2021
R6260 <10Mb on 100Mb Charter/Spectrum service
Our R6260 was working great at first. We have Charter/Spectrum 100Mb service on a Charter provided Arris TM1602 cable modem. Slow past month,at 10Mb. Tried resetting and redoing entire setup on R6260, and came out with same results.
This runs a PC, Xbox360, Xbox1, a few phones, and a laptop occasionally. Usually not more than 2 at a time.
Why would this slow down all of a sudden? It is on the latest available firmware, and no exotic setups.
Do I just try to get a replacement? How does one go about that?
Thank you.
  • Additional information:
    • I connected directly to the cable modem, and was getting 90 to maybe 95 Mb speeds on Ookla speed test.
    • I connect by wire to the Netgear R6260, and it is also slow, so it is not just the Wifi on this device.
    Question:
    I have not seen a firmware update in maybe a couple months. Please don't tell me this model is already out of date. I know I've had other devices that have had updates lasting many YEARS!
    Thank you.
    • plemans's avatar
      1. what actual firmware are you on?
      2. did you try a factory reset and reinstall?
      3. the R6260 is a base model device. You're not going to get the same amount/frequency of updates as you do from a flag ship router.
