lnbbrady's avatar
Oct 16, 2021
r6400 gets error message "trouble finding site"
  • Setup
    1. Home network on satellite connection through a modem
    2. Netgear AC1750 smart wi-fi router (model r6400)
      1. Firmware version V1.0.1.74_1.0.48
      2. Settings are set on auto-update, so I don’t know if a firmware update ran or not right before the problem began
    3. Computers (laptop and desktop) both running Windows 10 current version.
    4. Phone is Samsung Galaxy S20 FE (android)
  • Problem
    1. The problem has been going on for a while as I tried to figure out what was going on.  I don’t remember when it began.
    2. Both laptop and desktop, when plugged into router and I click on or enter an internet link, I often but not always, get this screen almost immediately
      1. Hmmm. we're having trouble finding that site
      2. We can't connect to the server at www.xxxxxx.com
      3. If that address  is correct, here are three other things you can try:
        1. try again later
        2. check your network connection
        3. if you are connected, but behind a firewall, check that Firefox has permission to acces the Web
        4. try again
    3. After hitting “try again” button, sometimes works, sometimes doesn’t
    4. Sometimes “try again” brings up a page that looks like the page data got to the computer, but it wasn’t interpreted and put in the right place.  Putting the cursor in the address area and hitting enter gets the page looking correct.
  • Testing
    1. Plugged laptop directly into modem and it doesn’t fail
    2. Put laptop on wi-fi and it never fails. At same time desktop on hard-wired still fails
    3. Phone on wi-fi never fails
    4. Turned off all Avast shields. Problem persists
  • Conclusion:
    1. The problem is in the router.
    2. Wi-fi portion of the router Is ok.
    3. Hard-wired portion of the router has the problem.
  • Questions
    1. Is the problem in the router hardware, which means buy a new router
    2. Or is it in the router settings.  What should they be and how did they possibly get changed?
  • Thanks for your help.  I'm heading to the correct forum to post the problem right now.  And I am now smarter, knowing what ONT means.  Now if I only had a reason to use the knowledge.  Being in a rural area, I know what fiber is, but can only wish for the speed it provides.  Heck, I'd be happy to get plain old-fashioned cable service. The digital divide does indeed exist.  I'm doing good to be able to use satellite service, slow as it is.
