ktyson068
Jan 22, 2021Aspirant
r6400v2 UPNP issues?
I have 2 xbox's connected through hardwire to my r6400v2 they have issues playing the same game together at the same time. My router is on its most recent firmware update, I did a factory reset earlier tonight. I am trying to avoid doing manual port forwarding because I have a rudimentary understanding of what I am doing and do not want to expose my network to any sort of security issues. I havew UPNP turned on but nothing ever populates in the portmap table.
- DarrenMSr. NETGEAR Moderator
You could try putting the xbox in the DMZ
https://kb.netgear.com/1118/How-do-I-configure-a-device-to-be-in-the-DMZ-on-my-NETGEAR-router
DarrenM
- ktyson068AspirantI ended up using static IPs and port forwarding 3074 and one of the alternates. That seems to have done the trick. I think the actual issue is the firewall in the modem and my ISP has locked me out of adjusting the settings for that. Thank you for reaching out with that.
