Resalith's avatar
Resalith
R6700 Download Speed stuck around 90mb
Hello all,
So I am using an Arris SurfBoard SB6183 connected to my new Nighthawk R6700. I'm supposed to be getting 200/20, but it is stuck at just under 90mb download speed. The upload is fine. The fw version is V1.0.2.60_10.0.44.
I've tested the modem by connecting it directly to my laptop, and I get the correct speeds, which leads me to think that it is not a modem issue.
I keep reading that it might be QoS On, but it is actually Off...
Edit: I also connected using ethernet port from the router and the speeds are also correct.
  • Nevermind! It looks like its related to a faulty WiFi USB adapter.
1 Reply
