Num1wop
Mar 21, 2017Aspirant
R6700 Not able to cast to device (Xbox One) from my windows 10 PC
Just bought the r6700 and can not cast to my xbox one anymore. Im sure its a streaming function in the router but I cannot find it. I tried with QoS enabled and Disabled, but neither worked. I would...
- Mar 24, 2017
Thank you for the information. I really needed that clarification. I followed the link and instead of adding the xbox, I deleted it and just re-added it. And they started communicating again.
ElaineM
Mar 22, 2017NETGEAR Employee Retired
Welcome to the community, Num1wop
Make sure that these devices are connected to the router.
Other than that it should work. There's no need to adjust settings like QoS.
You may also want to check the link below.
How to Stream Music and Video to Xbox One from Windows 10 PC
Num1wop
Mar 24, 2017Aspirant
