thepybus's avatar
thepybus
r6700 software upgrade using mac os router
The software upgrades offered on the site do not work with my Mac computer - the files are exec files not dmg
  • thepybus's avatar
    Mar 31, 2018
    I discovered the solution which did not necessitate directly downloading the software. I simply opened the Netgear Genie and went to Router Settings tab and after scrolling through I found a tab for router update and clicked on the "Next"button and it did the upgrade in about 4 minutes.
    It would be helpful if their was some note in the upgrade section of the website that mentioned that.
