fripn's avatar
fripn
R6700 WIFI won't turn on
Initially tried to set up through the Genie setup that auto runs via WIFI using the default SSID and Password.  During the initial set up it was working fine till the firmware update then it crashed ...
  • fripn's avatar
    Feb 20, 2017
    Getting it replaced after talking to support if someone could close out this thread.  Thanks!
