bucktaylor
Sep 06, 2025Aspirant
R6700AX issues with Roku's
I had an older Netgear router in an out building that ran 5 tv's either with roku's or via smart tv's. I replaced the older router with a neatgear R6700AX router and it triples my speeds which was ni...
Sep 08, 2025Guru - Experienced User
Which band are the roku's connecting to? 2.4ghz is a slow band and sensitive to interference.
Are you using smart connect on the R6700x? Could try disabling it so you can make the roku's select the 5ghz band
