bucktaylor
Sep 06, 2025Aspirant
R6700AX issues with Roku's
I had an older Netgear router in an out building that ran 5 tv's either with roku's or via smart tv's. I replaced the older router with a neatgear R6700AX router and it triples my speeds which was ni...
bucktaylor
Sep 10, 2025Aspirant
Thank you for the reply.
The Roku's I'm using (unless I'm mistaken) won't connect to 5ghz.
Netgear responded and told me to change the (primary, secondary, tertiary) DNS to 1,1,1,1 and 8,8,4,4 and 4,4,2,2 respectively ..... which I did..... that didn't solve it either. I know it is a very simple fix, I just am not smart enough to figure it out.... But somebody will solve it.
Thanks again!
