bucktaylor
Sep 06, 2025Aspirant
R6700AX issues with Roku's
I had an older Netgear router in an out building that ran 5 tv's either with roku's or via smart tv's. I replaced the older router with a neatgear R6700AX router and it triples my speeds which was ni...
Sep 10, 2025Guru - Experienced User
- what actual model roku are they?
- what channel on 2.4ghz are you using?
- Are you using any special characters in the ssid or password
- are you using wpa3 security or wpa2/wpa3 mixed mode?
