plshlpmyrouter
Feb 12, 2023Aspirant
R6700v2 Bridged Mode - internet becomes very slow on all network devices
Please excuse my ignorance - I am having a problem with my home network and I am not very network-lingo-savvy.
My desktop is connected directly by ethernet cable to a Nighthawk R6700v2 (firmware 1.2.0.42_1.0.1), which I have connected via Bridge Mode to my modem (Bell Home 3000). The internet connection on my desktop is extremely slow (2Mbps download compared to 200 for the other desktop connected directly to the modem), and the bridge mode setup seems to have slowed down the internet speed for all devices connected wirelessly to the network. The connection speed for the other devices returns to normal when I turn off the router.
Can I fix this? Is this a normal phenomenon? I can't seem to find a solution online.
Please let me know if I can provide any other information.
Again sorry for my lack of knowledge of network terminology.
Thanks.
This is a WiFi bridge? I ask because the bridge term means different things in different contexts.
Remember, a WiFi bridge isn't going to be that fast. But 2 Mbps isn't that good.
Then there is the complication of the Bell Home 3000. Not all modem/routers play nicely with bridged links.
This bit is odd:
...the bridge mode setup seems to have slowed down the internet speed for all devices connected wirelessly to the network. The connection speed for the other devices returns to normal when I turn off the router.
So all is well when the R6700v2 is off?
I'd be tempted to try Powerline Ethernet as an alternative.
- plshlpmyrouterAspirant
Thanks for your reply. I have set it up as a Wi-fi bridge, so the Nighthawk router connects to my modem over wifi.
It is quite weird and immediately noticeable that everything goes back to normal when the router is turned off.
I was wondering if the Bell Modem does not "like" having a router connected via bridge mode...
What channels are you using on the ISP Modem?
What is the distance between the modem and the wireless bridged R6700?
Does the modem support Smart Connect or do you have separate SSID names for 2.4 and 5Ghz?
Did you set the R6700 router to connect to 2.4Ghz or 5Ghz? 5Ghz would be recommended as it supports faster speeds.
