Tired8281's avatar
Tired8281
R6700v2 updater wants .chk, but website only gives me .img
I got a scary email from Netgear this morning telling me to update my router.  So I did what it told me, and when I extracted the zip, I got a .img file.  Went to upload that, it said, No, no, you need a .chk file.  I don't want to get ripped off like the other guy here did, where is the .chk file I need?
  • I used the Chrome OS zip unpacker.  But it's irrelevant, I boxed it up and sent it back to Amazon.  This thread should be locked.
  • FURRYe38's avatar
    Can you change the .img to .chk?
    What browser are you using? Try IE11 or FF browser to load FW. Factory reset the router first, the load the file, then if it takes, factory reset once more then set up from scratch.
    If this doesn't work, phone contact NG support about this or contact ElaineM here on the forums.
    • Tired8281's avatar
      Tired8281
      Wow, you seriously are advising me to rename a file to shoehorn it in as a firmware update?  That's the worst advice I ever heard.  I'm still within my return window with Amazon, think I'll just box it up and go for a more reliable brand.
