Dentyuns's avatar
Dentyuns
R6700v3 - Can't Log into Router
I'm at my wits end! I can't log into my router.
I took several hours on many days to do the following:
- I have the NightHawk app and used to go into it easily. Now it rarely finds connection to my router (even though I have internet) and when it does find my router, it gets stuck on the login page. I can't enter admin and password because it gets suck and says "timeout" session.
- Connects to wireless 2.4Ghz and 5.0Ghz, go to routerlogin.net or routerlogin.com. It just redirects me to a page that says I'm not connected to the router and need to get the NightHawk app.
- Connects to ethernet cable of my router. Routerlogin.net or routerlogin.com gets stuck and never loads.
- Use my default IP address. Also gets stuck and never loads.
- Used another computer following the same steps above. It doesn't work.
- Reset my router. Do the same steps as above. No dice.
Please help me in any way possible.
  • plemans's avatar
    what actual modem/gateway do you have it connected to?
    Is the router working fine otherwise?
    • Dentyuns's avatar
      Dentyuns
      It’s connected to CM600.
      The router is generally working fine, in the broadest statement. At times throughout the hours, it could very slow or no internet.
      But what I want to do is to access the router to enable the internet for my printer. But cannot in anyway access the router.
      • plemans's avatar
        Did you try a simple factory reset of the router? And then do a new install on it?
