barwick11's avatar
Apr 10, 2022
R6700v3 bottlenecking internet speed
We have an R6700v3 that we bought specifically for the internet controls.  We've been having issues with our internet but after diagnosing it, it turns out the issues are with the R6700 itself.  Any device connected to the router gets 85 Mb/s max.  When a device is connected directly to the cable modem we get 400 Mb/s.
I'd try Netgear support but of course they don't offer it anymore, despite their firmware updates causing ridiculously slow speeds now.  Any news from them on when they're actually fixing this in firmware?
    • barwick11's avatar
      barwick11
      Tutor
      Firmware V1.0.4.122_10.0.95
      Yes I've tried cables.  And the same cable from the router to modem was the same cable used from modem to PC (when the PC got 400 mb/s and the router got 80 mb/s)
      So, update on the status.  Yesterday I did a full factory reset on it, spent hours re-setting up all my settings.  I re-run the test, and it's running 400 mb/s after the factory wipe.  No clue why this should change anything, or why one should have to factory reset to get full speed from your router, and no clue how long this will last before it requires me to do yet another factory reset, but...
        barwick11
        Tutor
        Who decided this is fixed?  I got an email saying I have an accepted solution, come on here and my own answer "solved" the root problem?
        Obviously there's something else wrong going on here if RESETTING TO FACTORY is required to get your router to simply do what it's expected to do.  I don't think claiming this is solved is exactly accurate... it's a band-aid at best, and if Netgear can get away with thinking this is a viable solution, you get one guess how likely I am to buy their products ever again.
  • michaelkenward's avatar
    michaelkenward
    If this is a wifi connection, then it depends on the receiving end. 85 Mbps is as fast as some clients can manage. Nothing to do with the router.
    Do these things go a lot faster with different wifi sources?
