Ukaix9A
Nov 20, 2021Initiate
R6700v3 not showing all attached devices
My R6700v3 doesn't show all devices under "Attached Devices" that have been given a DHCP lease and are actively online. Firmware version is V1.0.4.120_10.0.91. Others have reported similar issues ...
michaelkenward
Nov 21, 2021Guru - Experienced User
You may not get much response with a vague comment like that.
You can look for "Attached Devices" in various places. Where are you looking? App? Browser? Genie?
Others have reported similar issues in threads I cannot reply to or bump: 1 2 3 4
Possibly because some of those messages are more than year, and several firmware versions, ago.
- CK77Dec 09, 2021Guide
I have the same happening on my R6700v3 router.
In the browser, when i look at the basic landing page, it shows me the correct amount of connected devices.
When i click to see all attached devices it only shows a few.
When i go to Access control i can see all connected devices there correctly.
But in access control you can't change the IP address or the logo for the device. So it's still useful to see the correct amount of devices on the Attached Devices page
Not sure about the Firmware version of my Router, I'm not at home at the moment, but it's the latest version for sure. I did a check in the brower and it says i'm on the latest one
- eelsj11Dec 15, 2021Initiate
I also have the same problem on my R6700v3 router running firmware V1.0.4.120_10.0.91.
I access the router webpage through the browser by logging into the router at address 192.168.1.1. On the main splash page, the "Attached Devices" panel shows "Number of devices: 16". When I click on the link for the "Attached Devices" on the left bar OR when I click on that dashboard panel stating 16 devices connected, I am brought to the "Attached Devices" page which only lists 2 devices.
- pkaytesDec 18, 2021Guide
My R7000 has the same problem since upgrading to V1.0.11.128.
# of Devices attached (Basic home tab after login) shows 18 devices but the Attached devices list only shows two.
