Langatun
Jan 25, 2018Aspirant
R6800 Changing DHCP default gateway
My home network (desired set up): - I have an old ISP-provided router (call it "router 1") connecting to the internet, and I don't want it to do anything other than routing to/from the internet. It's...
- Jan 25, 2018
> [...] D-Link 3680 ADSL router that doesn't seem to have a bridge mode
> or similar. [...]
Ok, if you say so.
> I have disabled wifi and DHCP, it only connects to the R6800 on its LAN
> port. It has a static LAN address: 192.168.1.2.
> - R6800 with wifi and DHCP enabled. All my devices (wired and wireless)
> connect to this. Address: 192.168.1.1, DHCP range 192.168.1.3 to *.254.
Why not use the DHCP server on this D-Link 3680? (And address ".1"?)
Similarly, why use the DHCP server on the R6800?
> - (Setting R6800 into AP mode won't do, as this also requires
> connection to router 1 on the WAN port and results in an extra subnet.)
No. With the R6800 in AP mode, you would have the one subnet
(determined by the D-Link 3680, which would need to provide the DHCP
server). That's what AP mode does.
> - Question: is there any way to fine-tune these DHCP settings on R6800
> so that router 1 is the only router on my network, but R6800 is the DHCP
> server?
Generally, no. Not with the normal user interface on the R6800.
You seem to be working very hard to do something which should be
pretty easy. Put the D-Link 3680 back to its default configuration.
Disable its wireless stuff if you want. (But why?) Configure the R6800
as a wireless access point (ADVANCED > Advanced Setup > Wireless Access
Point.)
My usual advice is to shrink the DHCP pool on the main router, and
assign a static, non-pool IP address to the access point ("Use fixed IP
Address (not recommended)."), so that it's easy to find the WAP. For
example, DHCP pool: ".2" - ".199", WAP IP address: ".200" or ".250".
(Something memorable, outside the pool.)
antinode
Jan 25, 2018Guru
> or similar. [...]
Ok, if you say so.
> server?
Point.)
