LewA
Jan 30, 2018Aspirant
r6900 dropping internet connection on 2.4, not 5.0
My Router R6900 with Firmware V1.0.1.36 continues to drop Internet on 2.4GHz for Windows 10 PC's, Macs, iPads. I have been using the R6900 for almost 2 years, and in the last few weeks began to have ...
- Jan 31, 2018
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
If I rename identical I am hopeful that most will simply reconnect.
That's what I do.
michaelkenward
Jan 31, 2018Guru - Experienced User
Got any Chromecast equipment?
- LewAJan 31, 2018Aspirant
I have a smartTV (4G), and also have a few year old TV with a wifi dongle. Both are connected via Wifi to the router.
- michaelkenwardJan 31, 2018Guru - Experienced User
I still don't know if you have anything Chromecast.
I asked because there has been a Google induced meltdown with some routers from a raft of makers.
Google Chromecast and Home devices are causing problems with some Wi-Fi networks – BGR
The symptoms are the same as you flagged up.
The worst hit Netgear products are the X7000X series of modems/routers and routers. I don't know about the R6900.
Did you factory reset after applying the new firmware last week?
I don't have any Chromecast hardware. I did not do a factory reset after applying the new firmware. I have been on for 24 hours since my last drop (2.4GHz channel change), which is progress. I can do the factory reset if you think that will help...just need to dust off some brain cells on how some of the devices connect/re-connect to the router (smartTV's, wireless printer, etc.). If I rename identical I am hopeful that most will simply reconnect.
