Stealth57
Jun 07, 2026Aspirant
R6900 says no Internet but extender does
This just started this morning. I cannot connect to the R6900 (same as 7000) with WiFi nor CAT5. Says no Internet; however, the extender that is connected to the exact same SSID from the router is fu...
- Jun 07, 2026
Power Off the modem and press the reset button in back of the router for 15 seconds then release. Power ON the modem. Give 2 minutes then with your hard wired PC connected, see if your web browser can start the setup wizard at 192.168.1.1
Jun 07, 2026Guru - Experienced User
What model cable modem do you have?
Factory reset the R6900 and setup from scratch with out the extender being online. Then make sure wireless and ethernet devices can connect to it there, if so, then connect the extender.
CAT6 cable is recommended between the modem and router.
