Stealth57
Jun 07, 2026Aspirant
R6900 says no Internet but extender does
This just started this morning. I cannot connect to the R6900 (same as 7000) with WiFi nor CAT5. Says no Internet; however, the extender that is connected to the exact same SSID from the router is fu...
- Jun 07, 2026
Power Off the modem and press the reset button in back of the router for 15 seconds then release. Power ON the modem. Give 2 minutes then with your hard wired PC connected, see if your web browser can start the setup wizard at 192.168.1.1
Stealth57
The modem is a CM1100. Side note, all the devices that won't connect were turned off last night. So, it is new connections that can't see the router. The extender runs 24/7, so it had a previously established connection.
