Stealth57
Jun 07, 2026Aspirant
R6900 says no Internet but extender does
This just started this morning. I cannot connect to the R6900 (same as 7000) with WiFi nor CAT5. Says no Internet; however, the extender that is connected to the exact same SSID from the router is fu...
- Jun 07, 2026
Power Off the modem and press the reset button in back of the router for 15 seconds then release. Power ON the modem. Give 2 minutes then with your hard wired PC connected, see if your web browser can start the setup wizard at 192.168.1.1
CrimpOn
Jun 07, 2026Guru - Experienced User
Stealth57 wrote:cannot connect to the R6900
Please explain "cannot connect".
- Obviously, a device wired to the router with a cable is "connected". Even if the device reports "no internet", it should be able to do various things with the router, such as
o 'ping' the router using its IP address
o connect to the router web interface using the IP address - In terms of WiFi, does the WiFi name (SSID) appear as one of the available networks?
Stealth57
Sitting at my Mac that has a hard connection to the router, I enter 192.168.1.1 and it says page failed to open. Connection to the extender via WiFi and the router log in appears. FYI, the Internet light on the router is blinking white. The manual says it should be solid white.
- FURRYe38Jun 07, 2026Guru - Experienced User
