Alan327
Feb 27, 2016Follower
R6900 vs R7000
What is the functional difference between the R6900 (Costco) and the R7000 (performance, software, features,etc) routers? I know the R7000 has an extra 2.0 USB port but the other specs seems to be ...
- Feb 28, 2016
here's NG's take on both devices.
http://www.netgear.com/home/products/networking/wifi-routers/r6900.aspx#tab-techspecs
http://www.netgear.com/home/products/networking/wifi-routers/R7000.aspx#tab-techspecs
You can't spoof a 6900 to look like a 7000 for 3rd party firmware..
netwrks
Feb 28, 2016Master
- JamesGLFeb 28, 2016NETGEAR Employee Retired
Hi Alan327,
You can check the comparison page for NETGEAR products to be able to check the difference.
