Alan327
Feb 27, 2016Follower
R6900 vs R7000
What is the functional difference between the R6900 (Costco) and the R7000 (performance, software, features,etc) routers? I know the R7000 has an extra 2.0 USB port but the other specs seems to be ...
- Feb 28, 2016
here's NG's take on both devices.
http://www.netgear.com/home/products/networking/wifi-routers/r6900.aspx#tab-techspecs
http://www.netgear.com/home/products/networking/wifi-routers/R7000.aspx#tab-techspecs
You can't spoof a 6900 to look like a 7000 for 3rd party firmware..
netwrks
Feb 28, 2016Master
JamesGL
Feb 28, 2016NETGEAR Employee Retired
Hi Alan327,
You can check the comparison page for NETGEAR products to be able to check the difference.
