clubmgr
Apr 16, 2022Aspirant
R6900P Firmware Upgrade Order
My R6900P router currently has firmware version V1.3.2.134
Both the Nighthawk app and the NetGear Genie app report that the firmware is up to date.
However, the NetGear support page lists V1.3.3.140 and V1.3.3.148 as also available.
I'm wondering if I it is ok to manually update from V1.3.2 to V1.3.3 with no issues?
And if so, do I have to update to V1.3.3.140 and then go to V1.3.3.148 in sequence?
Thanks. It would be helpful if their support page told you which prior versions can update to the listed version.
