Tperr24's avatar
Tperr24
R6900P kicks all devices off network (Ethernet & Wireless) when certain devices join
Hello,
I have an Arris Surfboard SB6190 Modem and a Nighthawk 6900P router (firmware - V1.3.3.142_10.1.75). COX is our service provider.
When I join the network with my personal laptop (on wifi) all other devices lose connection to the router. Even my work computer which is connected to the router via Ethernet gets disconnected. After they are able to rejoin the network, it will still take a minute or two before internet access is restored.
This seemed to start around the time I also started using NordVPN.  But seemed to work for a couple months with no issue so not sure if that is the source. I've also stopped using Nord and the issue still happens every time I join the network on my laptop.
I've tried updating the firmware (a while ago, I might be a little behind), and also turning off Dynamic QoS as I read on another post that can cause similar issues. I'm not sure what I should try next. Any thoughts welcome!
Thanks
  • plemans's avatar
    What happens if nord vpn is disabled?
    Maybe its creating some type of loop thats causing issues.
    • Tperr24's avatar
      Tperr24
      Thanks for your response. I was hoping the same. I disabled Nord from starting up about a month ago and haven't used it since but the issue has continued. My work computer requires me to be on a VPN so maybe somehow that is creating a loop. Tomorrow I will try disabling work VPN, and turning on my personal laptop and see if the issue continues.
      • plemans's avatar
        When its 1 device causing all the issues, it always make me look closer at that device versus the router/other devices connected.
